A clean A/B log before switching an Aqara device between Thread and Zigbee
When a dual-protocol Aqara device installs over Zigbee but fails over Thread, changing its position, network settings, and controller at the same time can hide which layer actually failed. I keep one short A/B log before deciding that the device or radio is defective.
Using the same phone and physical placement, I record:
  1. device firmware and the selected protocol;
  2. the Thread border routers or Aqara hub available during commissioning;
  3. the exact stage and wording of the failure;
  4. whether the accessory appears in the controller before the error;
  5. the result after one documented reset and a switch to the other protocol.
If Zigbee succeeds without moving the device, then Thread fails again from the same position, the comparison points toward the commissioning or controller path rather than mounting alone. I also separate “not discovered,” “joined but not reachable,” and “configured but missing features,” because those are different failures and need different evidence.
That small log makes a later support report reproducible and avoids losing the useful before-and-after state through repeated resets.
@jamesfengyuyang Love this approach — it’s exactly the kind of disciplined troubleshooting that saves hours of guesswork with dual-protocol hardware.
Your A/B structure neatly isolates the real failure domain. Keeping phone and placement constant while only changing protocol is the key control most people skip, and documenting the stage of failure (discovery vs. join vs. reachability vs. feature completeness) is particularly sharp — those manifest very differently in Thread vs. Zigbee commissioning flows.
One small addition worth logging: the LED state during each attempt. On Aqara’s dual-protocol switches, the blink color actually signals which protocol stack is active — blue/purple (or green/yellow depending on model) during pairing can confirm whether the device entered the expected mode after reset, which helps catch cases where the protocol switch itself didn’t take. It’s an easy visual cross-check against your documented steps.
The “one documented reset” rule is also smart — repeated resets without logging definitely burn the before-and-after state that support or community debugging would need.
Thanks for sharing this framework. Would be great to see how it evolves if you start adding Thread network topology (router path / RSSI per hop) to the log when available.
