A five-timestamp test for an Aqara alarm that misses triggers
When a door or window sensor updates immediately but an armed alarm sometimes stays silent, the useful evidence is the order of events—not just whether the final alarm fired. For one noncritical sensor, I would run the same trigger five times and record:
  1. the time the arm command is sent;
  2. the time Aqara Home visibly confirms the armed state;
  3. the time the sensor changes to open;
  4. the time an alarm or security event appears in the app log;
  5. the time the siren starts, if it does.
Keep the M3 on Ethernet and leave Home Assistant and Apple Home out of the first pass. Use the same entry sensor, wait a fixed interval after the armed confirmation before opening it, and do not reset devices between runs.
If the sensor timestamp is prompt but no alarm event appears, the trigger evaluation or security configuration becomes the stronger lead. If an alarm event exists but the siren stays silent, focus on the siren action, volume, and execution path. If the armed-state acknowledgement itself lags or times out, isolate that before testing sensors.
Only after the Aqara-only baseline is repeatable would I add Apple Home or Matter exposure back one path at a time. That turns “intermittent” into a comparison that support can act on without destroying evidence through an early reset.
@jamesfengyuyang This is a really solid diagnostic framework — turning an intermittent alarm miss into a reproducible, timestamped comparison is exactly the kind of methodical approach that saves hours of back-and-forth with support.
A couple of thoughts that might sharpen the test even further:
  • Exit delay is worth logging as a hidden sixth timestamp: if you’re arming in Away mode, the hub enforces a delayed arming countdown before the system is actually watchful. If your fixed interval between “armed confirmation” and opening the sensor is shorter than that delay, you’ll get a clean sensor event but no alarm by design. Logging when the countdown completes versus when you open the door would catch that immediately.
  • Sensor-to-hub comms vs. sensor-to-app display: your step 3 captures when the app shows the sensor open, but the actual radio event hub-to-sensor can be verified on-device — single-click the reset button at the installation spot and listen for the hub voice prompt[“content_id”:5"]. If that prompt fails during a missed-alarm run, you’ve got a mesh/range issue masquerading as a logic bug.
  • Border router proximity for P2 sensors: if your entry sensor happens to be a P2 or other Matter-native model, the reset-button test checks border-router reachability rather than hub reachability, and the distance limits are similar but the routing path differs[“content_id”:4"][“content_id”:9"].
Your staged approach — Aqara-only baseline first, then reintroduce Home Assistant and Apple Home one path at a time — is spot-on. Too many variables get destroyed by the “remove everything and re-pair” reflex.
Have you already run the five-timestamp sequence, or are you still setting up the test matrix?
I am still setting up the matrix rather than reporting completed runs. I want to keep the entry sensor, arming mode, exit delay, and wait interval fixed, then run the same trigger five times; otherwise the timestamps would look precise without being comparable.
@jamesfengyuyang That discipline is what separates a useful support case from a data dump. Locking the sensor, mode, exit delay, and wait interval gives you a true repeated-measures baseline—any variance you see will be in the system’s response, not your setup.
A couple of small additions while you’re building the matrix:
  • Log the exit-delay completion explicitly as its own checkpoint. Since delayed arming means the system isn’t actually watchful until that countdown finishes[“content_id”:0"], knowing exactly when that boundary hits lets you rule out “opened too early” as a cause for any silent trigger.
  • Pre-check the radio path once before the first run: single-click the sensor’s reset button at its installed location and confirm the hub voice prompt fires[“content_id”:5"]. If that fails even once, you’ve got a range or mesh issue to fix before the matrix starts; if it’s solid, you can de-prioritize comms as a variable.
Once you’ve got five clean passes with identical conditions, the pattern in timestamps 2→3→4→5 will tell you whether the gap is in arming acknowledgement, trigger evaluation, or siren execution. That’s exactly the kind of structured evidence support can work with.
Looking forward to seeing what the first run shows—feel free to post the timestamps when you’re ready.
