A Fun Project: Integrating Govee and Xiaomi Devices
Hey everyone! I wanted to share a fun project I’ve been working on. I’ve always been a fan of Govee and Xiaomi devices, and recently I decided to integrate them into my smart home setup. It’s been a fantastic journey, and I thought I’d walk through my experience in case it helps anyone else out there.First off, I’ve been using Govee remotes for a while now, and I absolutely love how versatile they are. I’ve set them up to control my TV, lights, and even my air conditioning system. The ability to customize the buttons and pair them with different devices is just amazing. But here’s where it gets interesting—I wanted to see if I could use my Govee remote to control my Xiaomi smart devices as well. After a bit of research, I found out that with the right setup, it’s totally possible!I decided to use Home Assistant as the central hub for my smart home. Setting it up was a breeze, and the integration with Xiaomi devices was seamless. For the Govee remotes, I had to do a bit more tinkering. I stumbled upon a great guide on how to use MQTT to bridge the Govee remotes with Home Assistant. It took a couple of tries, but I finally got it working!Here’s a quick rundown of what I did:1. Configuring Home Assistant: I installed the necessary integrations for Xiaomi devices and set up MQTT as the communication protocol.2. Setting Up Govee Remotes: I used the Govee app to pair my remotes and then configured them to send MQTT messages when buttons are pressed.3. Bridging the Two: I wrote some simple automations in Home Assistant that listen for MQTT messages from the Govee remotes and trigger actions on my Xiaomi devices.The result? I can now control my entire smart home setup using a single Govee remote! It’s incredibly convenient, especially when I’m relaxing on the couch and don’t want to fumble with multiple remotes.One thing I’d like to mention is the importance of community support. I ran into a few hurdles along the way, but thanks to the helpful folks in forums like this, I was able to troubleshoot and find solutions quickly. It’s amazing how much you can achieve with a little research and some guidance from others.If anyone else is looking to integrate Govee and Xiaomi devices, I’d highly recommend giving it a try. It’s a bit of a learning curve, but the end result is well worth it. Plus, it’s super satisfying to see everything working together smoothly!I’d love to hear if anyone else has tried something similar or has any tips to share. Let’s keep the ideas flowing! :blush:
