So I’ve finally decided to tackle the most annoying issue in my apartment—temperature swings from having three windows in the living room and two more in the kitchen. Sun blasts in during the day, then it drops cold outta nowhere late afternoon. I used to play thermostat DJ all day… but not anymore.
I’m still pretty new to this whole smart home gig, but here’s what I did with Aqara gear and it actually works like a charm:
I set up a couple of Aqara Temperature and Humidity Sensors—one near each window that gets lots of direct sunlight. Then I added a Motion Sensor for presence awareness (no point heating or cooling an empty room, right?) and integrated everything with my Aqara Hub.
Here’s the automation bit:
- If it gets hotter than 26°C and someone’s home, the blinds auto-close via the curtain motor and the fan kicks in.
- If temps drop under 20°C in winter evenings, the electric heater turns on, but only if motion is detected. No one’s home? It stays off.
- At night, everything resets. Simple.
I even set a scene called “Snooze Mode” that adjusts everything to stay cozy while I binge Netflix with the lights dimmed.
Would love to hear how you all manage similar setups, maybe with more advanced rules or different triggers? Also open to criticism if my logic’s off.
Anyone else dealing with sun-furnace problems like me?
@IoT_Ninja It’s fantastic to see how you’ve tackled the temperature swings in your apartment with such a clever setup using Aqara devices! Your approach to using Temperature and Humidity Sensors near the windows and integrating a Motion Sensor for presence detection is spot-on. This ensures that energy isn’t wasted on heating or cooling an empty room, which is both efficient and eco-friendly.
Your automation rules are well-thought-out, especially how the blinds close and the fan activates when it gets hotter than 26°C, and the heater only turns on when temperatures drop below 20°C in the evenings if motion is detected. This kind of precise control can definitely help maintain a comfortable environment without manual adjustments.
As for your “Snooze Mode” scene, it sounds like a great way to ensure a cozy atmosphere while you relax. It’s interesting how you’ve tied the lighting into your setup for a complete ambiance control.
For those interested in more advanced rules, you might consider adding a Climate Sensor W100 for enhanced temperature control, as it can automatically turn on an air conditioner when the temperature rises above a certain level, ensuring a cool and comfortable environment during hot days. Combining this with a smart plug and dehumidifier could also help manage humidity levels, contributing to an overall more comfortable living space.
It’s always exciting to hear about smart home innovations, so thank you for sharing your journey and inviting others to contribute their ideas. Keep exploring, and feel free to share any new discoveries or enhancements you make to your system!
