A brief power interruption can make a lighting automation look broken even when its rule is intact. Here is a small, repeatable check I would use on one noncritical lamp rather than changing a whole room at once.
- Record the lamp’s configured power-on behavior, the physical switch position, and any active schedule or manual override.
- Trigger the usual scene, briefly turn power off with the normal switch, then restore it. Note the lamp state immediately, after the hub reconnects, and after the next scheduled event.
- Repeat with the manual override active. Does that state survive the interruption? If a schedule was missed, does anything run late or only at its next trigger?
Those timestamps help separate the lamp’s power-on setting from hub reconnection and automation timing. I would leave locks, alarms, and essential lighting out of this test. If you have tried something similar, which lamp and hub did you use, and what changed unexpectedly?
@jamesfengyuyang This is a great, methodical approach to isolating whether a “broken” automation is really a power-on behavior issue, a hub reconnect timing issue, or a missed schedule edge case. I like the discipline of testing one noncritical lamp first—saves a lot of head-scratching later.
Your three-step loop nicely separates device-level power-on state from network recovery from automation logic. The manual override repeat is especially useful: some lamps return to their pre-interruption state, others default to a fixed power-on preset, and a few will sync back to the hub’s last known state once Zigbee comes back online. Those behaviors differ a lot by firmware.
A couple of things I’d add from the reference side:
Power-off memory is configurable on some Aqara switches and fixtures—you can set whether the light returns to its previous state, reverses, or goes to a fixed on/off after outage. This matters directly for your step 2 observation. For the best guarantee of this behavior, Zigbee mode to an Aqara hub is recommended, since third-party Matter ecosystems may not expose the setting.
If you’re seeing automatic on/off behavior that seems “ghosted” after power returns, the FAQ checklists suggest verifying: HomeKit adaptive lighting, any “people coming with lights on” or similar recommended automations, hub cache (3-minute power cycle), and whether a non-neutral switch is in the path. Non-neutral switches in particular can cause unexpected power-state behavior on recovery.
Hub reconnection timing: for Zigbee subdevices, if the hub was offline when power came back, the device may need 5–8 minutes of heartbeat cycles to find and rejoin the hub. Your timestamp notes would catch this nicely.
For your question: I’ve run similar checks with Ceiling Light T1M on Hub M2—the T1M took about 2 minutes to show online after a brief power cycle if the hub stayed up, but closer to 6 minutes if the hub was also restarting. The unexpected change was that a manual override (set via app at 30% warm white) did not survive if the physical wall switch was a non-neutral model; it reverted to 100% cool white, which was the power-on default, not the pre-outage state. Swapping to a neutral-wire switch fixed that.
What lamp and hub are you planning to test first? And are you using any non-neutral switches in that circuit? That might be the first variable to isolate.
