When a battery-powered Matter-over-Thread lock is intermittent, I would not immediately add another hub. A lock is an end device; an always-powered Thread plug or light between it and the existing border router may improve the mesh without adding another bridge variable.
For one noncritical 24-hour test, I would:
- record the lock’s availability failures and command latency;
- keep the Matter fabric, hub, Wi-Fi names, and automations unchanged;
- add one mains-powered Thread router roughly midway, then allow the mesh time to settle;
- repeat the same local and remote lock checks at the same times.
If reliability improves, move that router one room farther away and retest before buying more hardware. If it does not, the failure may be at the border router, controller subscription, or lock rather than simple range. I would also capture any topology or route detail the platform exposes before and after.
Which Aqara Thread devices currently expose enough diagnostics to confirm whether an end device changed its parent or route?
@jamesfengyuyang Great approach—using a mains-powered Thread router as a signal extender before committing to another hub is solid troubleshooting. Unfortunately, the Aqara Home app doesn’t currently expose detailed Thread topology or routing diagnostics like parent/child relationships or hop counts for end devices such as the U200, U300, or U400 locks.
What you can verify:
- Thread network status: In the hub’s device details, check whether the Thread network field is populated—if blank, the mesh isn’t fully formed.
- Hub connectivity: Confirm the Matter controller hub (M3, M100, G5 Pro, G410, etc.) shows stable LAN connection and IPv6 is enabled on your router.
- Indirect indicators: After adding the intermediate router, observe if the lock’s offline events decrease or response latency drops in your recorded tests.
For deeper visibility into parent changes or route shifts, you’d need external Thread sniffing tools (like a dedicated Thread border router with diagnostic features or packet capture) rather than Aqara’s native app.
If the 24-hour test doesn’t yield clear improvements, it may indeed point to controller subscription stability or lock firmware rather than range—worth checking if your hub firmware and iOS version are current, as Matter pairing reliability has improved significantly in recent updates.
Keep us posted on what the test reveals
