With Aqara devices spread across M3, M100, and M200 and exposed to Apple Home, I’ve found that ‘it feels slow’ is too vague to troubleshoot. A small latency matrix makes it easier to identify which layer changed.
Using one noncritical on/off device, I run the same test five times after 30 seconds of idle:
- Aqara Home → device
- Apple Home → Aqara Matter/HomeKit bridge → device
- A simple automation executed locally by the Aqara hub
I record median and worst-case latency, plus the hub, controller, firmware, and integration path. If all three paths are slow, I look at the device, mesh, or hub. If only Apple Home is slow, I focus on the controller/bridge path. If manual control is fast but the automation is slow, I inspect trigger conditions and simultaneous actions.
I avoid locks and safety-critical devices and change nothing between runs. Does anyone else track both median and worst-case latency, and what delay do you treat as a real failure rather than normal variation?
