Hey everyone, I wanted to share my recent experience integrating Alexa, Homey, and Logitech Harmony Hub. It was a bit of a challenge, but the result is seamless control over my home entertainment system. Here’s how I did it, in case you’re looking to set something similar up! The Goal: I wanted to use Alexa voice commands to control my Logitech Harmony Hub, which in turn controls my TV, receiver, and other devices. The aim was to say, “Alexa, turn on the TV” and have everything power up and switch to the right input automatically. The Setup: I started by purchasing the Homey Pro, which I heard is great for integrating different ecosystems. I installed the necessary apps for Alexa and Harmony Hub on Homey. The setup was pretty straightforward—just a matter of connecting the devices and configuring the activities on the Harmony Hub. The Challenge: Initially, I faced an issue where Alexa wasn’t recognizing the activities I set up. After some research, I realized I needed to ensure the Harmony Hub was correctly paired with Homey and that the activities were properly synced. I also had to make sure that the Alexa skill for Homey was enabled and configured correctly. The Solution: Once everything was correctly paired and configured, it worked like magic! Now, when I say, “Alexa, start Movie Night,” Homey sends the command to the Harmony Hub, which turns on the TV, receiver, and switches to the correct input. It’s incredibly convenient and has transformed how I enjoy my home theater. Tips for Others: - Pairing is Key: Make sure all your devices are correctly paired with Homey before setting up voice commands. - Test Activities Individually: Before linking everything, test each activity on the Harmony Hub to ensure they work as expected. - Check Alexa Skills: Ensure the Homey skill is enabled and up-to-date in your Alexa app. This integration has been a game-changer for me, and I’m excited to explore more possibilities with Homey. If you’re looking to connect multiple ecosystems, I highly recommend giving it a try! ![]()
