A three-checkpoint log for Matter devices that stay online in Aqara Home but go stale elsewhere
When a device still works in Aqara Home but becomes stale in Apple Home or Home Assistant, I capture three timestamps before rebooting anything: the last update in Aqara Home, the last update in the Matter controller, and whether the Aqara hub or bridge was reachable at that moment.
Then I change one layer at a time—refresh the controller, check the hub or bridge, and only then power-cycle the end device—and note which timestamp resumes. That small log helps separate an end-device problem from a bridge or Matter-fabric problem and gives support a much cleaner starting point. What else do you record before resetting a pairing?
Are you grabbing the timestamps manually or did you find a way to log this automatically?
I meant a manual comparison as a starting point; I do not have a tested cross-platform logger to share. Where an app exposes no event timestamp, I would record the observation time and label it as such, rather than call it the last device update. A shared UTC clock and one deliberately triggered sensor change would make the separate records easier to compare.
