A100 battery level stays around 80%, then suddenly dies โ€” no low battery warning
Hello Aqara team and A100 owners,
I have a recurring battery detection problem with my Aqara Smart Door Lock A100. This has happened three times.
In each case, the lock showed around 80% battery level, but there was no low-battery warning or voice notification. Then the batteries suddenly became critically low.
The display started flashing, and the lock was barely able to unlock the door.
After I replaced the batteries with another partially discharged set, the lock immediately detected the low battery and started giving the โ€œLow batteryโ€ voice warning and showing the red battery indicator.
This makes me think that the low-battery warning itself works, but the battery level estimation may be inaccurate. The lock can show around 80% even when the batteries are already close to being completely discharged.
Could this be a firmware or battery-level detection issue?
Is Aqara aware of this problem, and is there a planned firmware update to improve battery level detection and provide the warning earlier?
Please let me know if there is any way to diagnose this problem, for example by checking the firmware version, battery voltage, logs, or power consumption.
Thank you.
Hi there, it looks like youโ€™re experiencing a support-related issue. Weโ€™ve automatically created a support ticket for you and will reach out via the forum email within the next two business days.
What kind of batteries did you use?
Just chiming in to say I have the same issue (and have had it since I purchased in 2022). I use Energizer Max AA batteries.
In addition to this issue, I am also having a really bad experience with battery life. Recently it has only been lasting as little as a month before I have to change batteries.
Iโ€™m open to trying different batteries if anyone has recommendations. But it would be more helpful to have an accurate battery level indicator.
I monitor the battery using the Home Assistant integration. Hereโ€™s the past few months. The red circles indicate when the door lock stopped working.
I have used different brands of alkaline batteries, including Duracell, Philips, and Nanfu.
The same problem occurred with all of them. The batteries suddenly became critically low, without any low-battery warning or voice notification from the lock.
So it does not seem to be related to a specific battery brand.
Iโ€™m experiencing a similar issue with the battery level indicator. The app can still show around 80% battery remaining even when the batteries are already depleted and the lock stops working. The lock does not provide a reliable low-battery warning, so the battery indicator is essentially useless when it matters most.
Iโ€™ve contacted Aqara support several times, but unfortunately, this has not led to any real solution. Iโ€™ve always used alkaline batteries, checked the battery contacts, and confirmed that the batteries are installed correctly.
Aqara keeps suggesting that I replace the batteries or replace the indoor panel, but they havenโ€™t provided a clear technical explanation for the problem. They donโ€™t seem willing to acknowledge that this could be a product defect or an issue with the firmware or battery-level detection algorithm.
What I find particularly frustrating is that Aqara doesnโ€™t seem to be considering a firmware update as a possible solution. If the lock incorrectly calculates or reports the remaining battery level, why canโ€™t the battery detection algorithm be investigated and corrected through a firmware update? Has Aqara confirmed that this is definitely a hardware problem, or have they actually investigated whether the issue could be fixed in software?
Before asking customers to replace hardware, I believe Aqara should properly investigate the root cause and determine whether a firmware update could improve the accuracy of the battery indicator and provide a reliable low-battery warning.
Since other users are reporting similar problems, this may be a broader issue rather than an isolated case. Itโ€™s frustrating that the lock can become unusable while the app still shows a substantial amount of battery remaining, yet support offers no clear explanation or software fix.
Has anyone managed to get a definitive answer from Aqara about whether this issue can be fixed with a firmware update?
