Achieving Dynamic Philips Hue Automation Based on Brightness Levels
I’ve been diving into creating a sophisticated automation system for my Philips Hue lights, and I wanted to share my journey and insights in case others might find it helpful or interesting. The goal was to have a single button press trigger different lighting scenarios based solely on the current brightness of my living room lights. Here’s how I approached it and what I’ve learned along the way.
The Vision
I envisioned a system where pressing a button on my Philips Hue Tap Switch would do the following:
  • Turn lights on to 100% brightness if they’re off.
  • Adjust to 66% brightness if currently above 66%.
  • Drop to 33% if between 33% and 66%.
  • Lower to 5% if between 5% and 33%.
  • Turn off entirely if at or below 5%.
The Challenge
While the concept seemed straightforward, implementing it was a bit more complex. I quickly realized that each condition required its own automation, as the system couldn’t handle multiple conditions within a single rule. This meant setting up several automations, each monitoring the brightness and triggering the appropriate scene.
The Process
  1. Setting Up Scenes: I started by creating scenes for each brightness level (100%, 66%, 33%, 5%, and off). This allowed me to easily reference these states within my automations.
  2. Creating Automations: For each brightness threshold, I created an automation with a trigger (the button press) and conditions (current brightness level). The action was straightforward—activating the corresponding scene.
  3. Testing and Debugging: This was the most time-consuming part. I tested each automation individually to ensure they worked as intended. I encountered a few hiccups, like the system not recognizing the brightness levels correctly, but adjusting the conditions and delay actions helped.
Key Insights
  • Brightness Thresholds: Using numeric state conditions was crucial. I had to ensure the thresholds were set precisely to avoid overlaps or gaps.
  • Delay Actions: Adding a small delay (0.2 seconds) before executing the scene helped prevent any potential race conditions or missed triggers.
  • Automation Structure: Keeping each condition separate made troubleshooting easier. If one automation wasn’t working, it didn’t disrupt the others.
The Outcome
After several iterations and adjustments, the system now works seamlessly! Pressing the button adjusts the lights exactly as intended, creating a dynamic and responsive lighting setup. It’s incredibly satisfying to see everything come together and function so smoothly.
Tips for Others
  • Start small. Test each automation individually before combining them.
  • Keep your conditions clear and specific to avoid overlaps.
  • Don’t hesitate to adjust delay actions if you’re experiencing any timing issues.
This project has been a fantastic learning experience, and I’m excited to explore even more automation possibilities with my Philips Hue setup. If anyone has similar projects or questions, I’d love to hear about them or help out!
