I recently embarked on a project to create a climate controller using ESPHome, specifically a ‘Dual-point’ thermostat to manage both heating and cooling for my room. While the setup itself was straightforward, I encountered an intriguing challenge that I wanted to share and explore with the community.
The goal was to integrate a light sensor into the system, which would trigger the air conditioning when the light intensity exceeded 600 lux, such as when the sun shines through my window. This would help maintain a comfortable室内环境 by preemptively cooling the room.
However, implementing this scenario proved to be more complex than anticipated. The challenge lies in how to override the thermostat’s default settings and directly command the air conditioning system to reach the lower temperature threshold. I experimented with various configurations within Home Assistant, but none seemed to provide the desired seamless integration.
I would love to hear from others who may have tackled similar projects or have insights into whether this can be achieved within the existing framework or if custom scripting is necessary. Any advice or experiences shared would be invaluable as I refine this project further.
Key Takeaways
- Project Overview: Integrating a light sensor with a thermostat for adaptive cooling.
- Challenges Faced: Overriding thermostat settings via light sensor input.
- Seeking Solutions: Methods to directly control AC based on light intensity within Home Assistant.
Looking forward to your thoughts and experiences!
