I recently embarked on a journey to streamline my smart home setup, specifically aiming to control my garage door using Google Assistant without relying on IFTTT. The goal was to create a simple voice command like “Hey Google, Open the garage door” with a clean response and no additional phrases. While I initially used IFTTT to achieve this, I was eager to find a more robust solution that didn’t involve third-party services.
After exploring the Home Assistant Google Assistant Integration, I encountered a few challenges. The project expiry issue was a major concern, as it required constant retesting every 30 days, which wasn’t practical. Additionally, the mandatory use of a project name in custom commands felt cumbersome and deviated from the seamless experience I was aiming for.
Through experimentation, I discovered that integrating Google Routines with Home Assistant provided a reliable workaround. By setting up routines directly within Google Assistant, I could trigger specific actions without the need for project names or additional phrases. This approach not only eliminated the project expiry issue but also maintained the clean response I desired.
Here’s how I achieved it:
- Setup Google Routines: I created a routine named “Open Garage Door” and linked it to the action of opening my garage door via Home Assistant.
- Voice Command Integration: I trained Google Assistant to recognize the phrase “Hey Google, Open the garage door” and map it directly to the routine.
- Response Customization: While Google Assistant doesn’t allow custom responses, the default confirmation sufficed for my needs.
This solution has been running smoothly for several weeks, and I’m thrilled with the results. It’s been a great way to integrate Google Assistant more deeply into my smart home ecosystem without compromising on functionality or user experience.
If anyone has questions or needs assistance with similar setups, feel free to reach out! I’d be happy to share more details or troubleshoot any issues you might encounter.
