I’m currently working on setting up an automation in Home Assistant to reset the manual control flag for my Adaptive Lighting integration after a certain period of inactivity. Here’s what I’ve got so far and where I’m stuck.
Setup Details
- Home Assistant Version: 2025.7
- Adaptive Lighting Instance: AL FoH
- Lights Controlled: Zigbee (ZHA) two-bulb pairs (
dining_room_lights_z,livingroom_lights_z,bedroom_lights_z,office_lights_z)
Goal
I want the automation to reset the manual_control flag for the Adaptive Lighting instance after 1 hour of inactivity. This means if I manually adjust the lights, the system should automatically revert to its scheduled settings after 60 minutes.
Current Automation Configuration
Here’s the YAML configuration I’m working with:
yaml
alias: “Adaptive lighting: reset manual_control after 1 hour”
mode: parallel
trigger:
platform: event
event_type: adaptive_lighting.manual_control
variables:
light: “{{ trigger.event.data.entity_id }}”
switch: “{{ trigger.event.data.switch }}”
action:
- delay: “01:00:00”
- condition:
template
value_template: “{{ light in state_attr(switch, ‘manual_control’) }}” - service: adaptive_lighting.set_manual_control
data:
entity_id: “{{ switch }}”
lights: “{{ light }}”
manual_control: false
Challenges
- Understanding Variables: I’m not entirely clear on how
lightandswitchvariables are being populated. Shouldswitchrefer to the Adaptive Lighting instance (switch.adaptive_lighting_al_foh)? - Entity ID Confusion: The lights are part of Zigbee groups, not HA Helper Light Groups. Does this affect how the automation targets them?
- Testing and Debugging: I’m unsure how to test this effectively. Should I manually trigger the event to see if the automation works?
Seeking Help
- Variable Clarification: What exactly should
lightandswitchrepresent in this context? - Entity Targeting: How do I ensure the automation correctly targets the Zigbee group lights?
- Testing Advice: Any tips on how to debug this automation would be incredibly helpful.
If anyone has successfully implemented a similar automation or can shed light on these variables, I’d greatly appreciate your insights!
Best regards,
