I recently dove into setting up adaptive lighting in my home, and it’s been a game-changer!
I’ve been using the circadian_lighting component, which has made my evenings much more relaxing. The gradual shift in color temperature as the day progresses is so seamless, and it really does make a difference in how I feel. However, integrating it into the core system was a bit tricky at first. After some research and tweaking, I managed to get it working perfectly with my Philips Hue bulbs. The best part? The ability to customize the settings to match my daily routine. I even set it up to adjust based on my location’s sunrise and sunset times, which adds that extra touch of personalization. If anyone is looking to try this out, I’d highly recommend starting with the default settings and then gradually adjusting them to see what works best for you. The community support is also fantastic, with plenty of resources and forums to help you along the way. Happy lighting! ![]()
