Adjusting Automation Triggers with Time Offsets
Hey everyone! I wanted to share a little trick I figured out for adjusting automation triggers with time offsets. I’ve been working on a project where I need an automation to trigger 30 minutes before a specific time, but I wasn’t sure how to set that up initially. After some research and experimentation, I found a solution that works perfectly!
Here’s what I did: I used a combination of value_template and a time offset in my automation setup. The key was to subtract the desired time from the target time. For example, if I want something to happen at 8:00 AM, but 30 minutes earlier, I set it to trigger at 7:30 AM. This might sound simple, but getting the syntax right was a bit tricky!
I also discovered a handy way to visualize this in the developer tools. By creating a small test automation, I could see exactly how the time offset affected the trigger. It made it much easier to tweak and ensure everything was working as expected.
If anyone else is trying to do something similar, I’d love to hear how you approach it! Do you have any tips or alternative methods for adjusting automation times? Let’s share and learn together! :blush:
