Adjusting Focus on My New Floor Lamp
I recently purchased a new floor lamp, and I must say, it’s been a great addition to my home. The setup was straightforward, and the finish and light quality are stunning. However, I encountered a small issue that I wanted to share in case others are facing the same problem. The lamp’s focus adjustment wasn’t as intuitive as I expected. Despite looking through the manual and trying a few methods, I couldn’t figure it out right away. After some research, I discovered that the focus can be adjusted by gently twisting the bulb housing. It was a simple solution, but not immediately obvious. I’m happy to say it works perfectly now, and the light is even more enjoyable to use. If anyone else is struggling with this, I hope this tip helps!
