Adjusting Music Sensitivity in DreamColor Lights
Hey everyone! :star2: I just wanted to share a quick tip that might help others who are experiencing the same issue as me with the DreamColor lights. I absolutely love these lights and the app is so user-friendly, but I was having a bit of trouble with the music sensitivity. It was picking up almost every background noise in my room, which was a bit annoying! :headphones::loud_sound:
After a bit of experimentation, I found that adjusting the sensitivity settings made a huge difference. If you’re struggling with the same issue, here are a few tips that might help:
  1. Lower the Sensitivity: Go into the app settings and try lowering the sensitivity. This can help reduce the number of false triggers from background noise.
  2. Use Noise-Canceling Headphones: If you’re using the lights with music, try using noise-canceling headphones to reduce external noise interference.
  3. Position the Light Carefully: Experiment with the placement of the light to find the sweet spot where it picks up the music but not too much background noise.
  4. Update the Firmware: Make sure your lights are running the latest firmware, as updates often include improvements to sensitivity settings.
I hope these tips help someone out there! Let me know if you have any other questions or if you’ve found a solution that works even better. :rocket::sparkles:
