Hey everyone, I wanted to share my experience with fine-tuning the presence sensor on my phone app to better suit my daily commute. I’ve been using it to automate my smart home system (SHM) based on my proximity to home, but the default settings weren’t quite cutting it for my needs.
The Setup:
I’ve set up the presence sensor to arm or disarm my SHM and notify me when there’s a change. My commute involves walking from the train station to my home, a path that’s about 400 meters with some turns and a stream crossing. It usually takes me around 7 minutes to cover this distance. The sensor reliably triggers at the same spot every time, but this consistency has its downsides.
The Challenges:
- Unexpected Stops: If I pause my walk to chat with a neighbor, the sensor still triggers at the same spot. This means my system might disarm too early, unlocking doors and turning on lights before I’m actually ready to enter.
- Erratic Notifications: While running errands, I’ve noticed the sensor sometimes flips my presence status when I’m several streets away from home. This leads to unnecessary notifications and system changes.
The Solution:
After some research, I discovered that tweaking the sensor’s threshold could help. I hypothesize the default sensitivity is set to 400 meters, but I’d love to test it at a shorter range, say 100 meters or even 50 meters. This adjustment should make the sensor more responsive to my immediate surroundings and reduce false triggers while I’m out and about.
What I’m Hoping for:
I’m curious if others have encountered similar issues and how they’ve resolved them. Has anyone successfully adjusted their presence sensor sensitivity? Any tips or tricks would be greatly appreciated! I’m also wondering if there’s a way to set different sensitivity levels for various activities, like commuting versus running errands.
Let me know your thoughts or if you’ve got any advice on optimizing this setup. It’d be awesome to hear how others are making the most of their presence sensors!
