Hey everyone, I’m working on a project where I need to adjust the rotation range of a servo motor in Home Assistant. I’ve been using a servo for a blast gate, and it currently rotates about 70 degrees. I’ve redesigned the gate and want the servo to rotate 180 degrees instead. I’ve tried tweaking the min_level and max_level values in the configuration, but it either doesn’t change anything or the servo stops responding altogether. I’m a bit stuck here and would love some advice on how to properly adjust the rotation range. Has anyone else encountered this issue or have tips on how to solve it? I’m really curious to see if there’s a way to achieve the full 180-degree rotation without running into these problems. Thanks in advance for any help!
