Adjusting Wyze Cam Recording Times for Better Surveillance
Hey everyone, I’ve been experimenting with my Wyze Cams lately and wanted to share some tips on adjusting their motion detection settings for better surveillance. I recently upgraded to the Wyze Cam v2 and have been using it to monitor my backyard, especially for wildlife like the occasional visiting hummingbird. However, I noticed that the default motion detection settings were a bit too sensitive, often triggering false alarms from nearby trees swaying in the wind.
After some trial and error, I found that tweaking the detection distance and image sensitivity settings made a huge difference. I set the detection distance to 11 meters and increased the image sensitivity to 91, which helped reduce false triggers while still capturing movement effectively. I also activated CamPlus to enhance the video quality, making it easier to identify what’s moving in the frame.
Another thing I discovered is the importance of placement. I mounted the cam slightly higher than recommended to get a better view of the feeder without the branches obstructing the lens. This adjustment helped in getting clearer footage and reduced the chances of the feeder itself causing shadows that might trigger the motion sensor.
I’d love to hear how others are optimizing their Wyze Cams for different scenarios, whether it’s for pets, wildlife, or general home surveillance. Have you found any particular settings or strategies that work exceptionally well? Let’s share our experiences and tips to help each other get the most out of our smart cameras!
Cheers,
