Hey everyone, I’ve been diving into OpenHAB automation lately and wanted to share some insights and tips that might help others avoid some common pitfalls. I recently set up a flow using a door sensor to trigger music playback on a Sonos system every Friday between 3 PM and 6 PM. The setup works for the most part, but there’s this annoying issue where if the song is already playing and the door sensor gets triggered again, the music stops and starts over. It’s a bit jarring, to say the least!
After some research and experimentation, I found that the issue arises because the flow isn’t checking if the music is already playing before triggering the playback command. To fix this, I added a conditional check in the rule to ensure the Sonos device isn’t already active before restarting the music. This simple adjustment has made a world of difference!
Here’s a quick breakdown of the rule I’m using now:
plaintext
rule “Friday Music Flow”
when
Item DoorSensor changed to OPEN
and
Time cron “0 15-18 * * FRI”
then
if (SonosDevice.state != PLAYING) {
SonosDevice.sendCommand(PLAY, “certain_song.mp3”)
end
This approach ensures that the music only starts if it’s not already playing, preventing those unwanted restarts. I’d love to hear if others have encountered similar issues or have additional tips for refining automation flows!
Another thing I’ve been experimenting with is integrating multiple triggers for more dynamic automation. For example, combining motion sensors with door sensors to create a more responsive system. It’s been a fantastic learning experience, and I’m excited to see how much further I can push the capabilities of OpenHAB!
If anyone has questions or needs help troubleshooting their own automation setups, feel free to reach out. Happy automating! ![]()
