Advise about perfect position of fp2 sensor
What would you suggest optimal placement for fp2 in a long rectangle room ?
@lineredzed For optimal placement of the Aqara Presence Sensor FP2 in a long rectangular room, you might want to consider the wall-mounted installation method. This is because it provides a horizontal detection angle of 120 degrees, with a radial detection distance of up to 8 meters, which is well-suited for covering elongated spaces.
If you are focusing on zone detection, placing the sensor along one of the longer walls can help maximize coverage across the length of the room. Make sure to install it free from potential interferences like glass, mirrors, or metal objects, which could affect detection accuracy. Also, consider marking areas with possible disturbances, such as fans or curtains, as interference zones for optimal performance.
Feel free to share your experiences or any unique challenges in setting up your space!
@lineredzed For optimal placement of the FP2 in a long rectangular room, here are some key suggestions based on installation guidelines:
  • Mounting method: Wall-mounted is recommended for zone detection, as it offers a 120-degree horizontal detection angle, 8-meter radial distance, and 6-meter width, which can help cover the room effectively .
  • Height: Install at 1.4-1.8 meters in a regular home setting (or 2+ meters for larger spaces); if mounted higher, point the sensor slightly downwards to ensure coverage .
  • Avoid interference: Select a location free from disruptions like glass, mirrors, metal, or moving objects (e.g., fans, curtains). If unavoidable, position these in the sensor’s blind spots .
  • Edge configuration: Define the maximum detection area and set areas beyond walls or non-target zones as “edges” to reduce false targets from signal reflections .
  • Verify placement: After binding, check if the device’s home page shows a human icon and movement path matching your activity—this indicates normal operation (note: slight delays from network/server communication are expected) .
You might also adjust sensitivity or use the “AI learning function” if needed. Have you tried any of these steps already? Sharing your experience could help others too!
Note: Information is based on reference materials; actual results may vary by environment.
@lineredzed For optimal placement of the FP2 in a long rectangular room, here are some key suggestions based on the sensor’s characteristics:
First, wall-mounted installation is recommended for zone detection, as it offers a 120-degree horizontal detection angle and a radial distance of up to 8 meters, which can help cover the length of the room effectively . Mounting it on one of the longer walls (rather than the shorter ends) may maximize coverage of the room’s length, but ensure the sensor’s 120-degree angle aligns with the room’s layout to minimize blind spots.
Second, pay attention to installation height. For regular home settings, a height of 1.4-1.8 meters is ideal; for larger spaces (like a long room), a height of over 2 meters is acceptable, but the sensor should be pointed slightly downward to focus on the activity area . Incorrect height can lead to detection errors, so adjusting this based on the room’s size is crucial .
Third, configure edge settings to reduce false alarms caused by signal reflections from walls. Define the maximum detection area (covering the room’s interior) and set the area beyond the walls as edges, which helps the sensor focus on the actual space .
Additionally, mark interference sources (e.g., curtains, fans, or moving objects) in the app to avoid false detections. Ensure no such objects are within the primary detection zone .
You might also test different positions and use the “Space Intelligent Learning” function (when the room is unoccupied) to optimize detection accuracy .
Have you tried any placement yet? Sharing your experience could help others in similar setups!
