Aeotec Z-Wave Stick Gen5+ Integration and Configuration Tips
I recently made the switch from SmartThings to Hubitat and decided to integrate my Aeotec Z-Wave Stick Gen5+ into my setup. The process was a bit daunting at first, but I wanted to share my experience and some tips that might help others going through a similar migration.
Initial Setup and Configuration
After excluding all my Z-Wave devices from SmartThings, I included them into the Aeotec Z-Wave Stick Gen5+. The goal was to use this stick as a secondary controller alongside Hubitat. However, I faced some challenges in pairing the stick with Hubitat. After several attempts, I realized that the key was to ensure both devices were in inclusion mode simultaneously. This required some patience and careful timing, but once paired, the integration was seamless.
Dual Controller Configuration
I explored the idea of using a dual controller setup with Domoticz and Hubitat. While this configuration offers flexibility, I found it a bit complex for my needs. Instead, I decided to use Hubitat as the primary controller and leverage the Aeotec stick for specific tasks, such as managing legacy Z-Wave devices. This approach simplified my setup and ensured optimal performance.
Key Takeaways
  1. Patience is Key: Pairing the Aeotec stick with Hubitat requires precise timing and multiple attempts.
  2. Simplify Your Setup: Unless you have a specific need for a dual controller setup, consider using the stick for niche purposes rather than complicating your ecosystem.
  3. Import Devices Directly: If you’re migrating from another platform, importing devices directly into Hubitat can save time and reduce complexity.
Conclusion
The Aeotec Z-Wave Stick Gen5+ is a powerful tool for expanding your Z-Wave network. While the initial setup can be challenging, the benefits of having a reliable secondary controller are well worth the effort. I’m now enjoying a more streamlined and efficient home automation system, and I hope these tips can help others achieve the same.
