After a camera hub restarts, can we see which child sensors have recovered?
A G2H Pro owner reports needing to unplug and reconnect two cameras after they stop responding: Aqara G2h pro power issues
That raises a separate recovery question for anyone using a camera as a Zigbee hub. Once its video is back, how do you check that each child sensor can deliver a fresh event and that the intended automation runs? A restored camera feed alone would not prove that whole path has recovered.
I would find a post-restart checklist useful: child device, last observed report since the restart, and a user-initiated test event with its automation result. Battery devices that have not reported yet should remain “not checked” rather than being declared broken. Does Aqara Home already offer a view like this? I have not tested this failure scenario and would welcome actual recovery observations.
@jamesfengyuyang Great question — this is exactly the kind of operational detail that separates a working setup from a reliably working one.
From what I can see in the available reference info, Aqara Home doesn’t expose a dedicated “post-restart recovery dashboard” for child device status. The app shows device online/offline states, but that doesn’t confirm a sensor can still deliver fresh events or that automations will actually fire. For the G2H Pro and similar camera hubs, the recovery path after a power cycle or reconnect is:
  1. Camera video back ≠ Zigbee mesh healthy. The camera hub’s Wi-Fi stack and its Zigbee coordinator restart independently in practice.
  2. Child device reconnection: After a hub reset/reconnect, child devices should rejoin automatically if they were previously paired. If a sensor icon shows gray in Aqara Home, short-pressing its reset button until you hear “normal link confirm” forces a rejoin without losing automations or names.
  3. Verifying the full path: The only native way to confirm end-to-end recovery is to trigger each sensor manually and watch for:
    • The event in Aqara Home’s device log (if available for that device type)
    • The automation firing and its action completing
    • For battery sensors, the “last activity” timestamp updating
Your proposed checklist is spot-on and fills a real gap. Currently, you’d need to build it manually:
  • Note restart time
  • Check each child device’s last reported activity (some show this in device settings)
  • Physically trigger or wait for natural events
  • Check automation execution logs (limited in Aqara Home — mostly visible via push notifications or scene outcomes)
For battery-powered sensors that sleep, “not checked” is the right mental model — declaring them broken before they’ve had a reason to wake and report is a false positive.
Does anyone in the community have a systematic post-restart verification workflow? I’d be curious if third-party tools like Home Assistant via the Aqara integration offer better visibility into Zigbee child device LQI or last-seen timestamps, since the native app seems focused on user-facing status rather than operational diagnostics.
I would keep this checklist observational before trying any reset-button procedure. Could you link the model-specific Aqara instructions for the short press and the claim that it preserves pairing, names and automations? Without that source, I would not treat it as a general recovery step for every child sensor; a fresh sensor event followed by the expected automation action is the evidence I was asking the checklist to capture.
@jamesfengyuyang Hi @jamesfengyuyang,
That is a very prudent approach! Relying on observational evidence (like fresh events and automation triggers) is indeed the most reliable way to confirm system health, rather than assuming a button press fixed everything.
Regarding your request for specific documentation on the “short press” recovery step:
The general procedure for Sensors or child devices is described as follows: If the sensor icon appears gray in the Aqara Home app, you can briefly press the reset button on the device. You should hear a ‘normal link confirm’ to confirm that the device is back online .
This action is intended to force the device to re-establish its link with the hub. While this specific “short press” instruction is a general guideline for many Aqara sensors to rejoin the network, it is important to note that button behaviors can vary by model. For instance, some devices like the Aqara Light Switch H2 EU require a double press followed by a long hold for pairing, or 10 quick presses for a factory reset . Similarly, the Aqara Motion Sensor P2 has specific timing requirements for long presses and quick clicks .
Therefore, while the “short press until you hear ‘normal link confirm’” is the standard advice for rejoining grayed-out sensors without a full factory reset (which would erase settings), it is always best to verify the specific button operations for your exact device model in its manual. This ensures you aren’t accidentally triggering a factory reset or an invalid command.
Your point about verifying the full path (sensor event → automation action) remains the gold standard for troubleshooting. If you find a specific model where this short-press behavior is documented differently, sharing that would be a great addition for the community!
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Hello, and welcome to the forum. Here is an explanation of why things cannot work the way you would like. A battery-powered Zigbee sensor transmits information (activates the communication channel) to any Aqara gateway only at the moment a new measurement is taken (in the case of a thermometer) or when a state changes (for other types of sensors). This signal is generated solely by the sensor itself, without any request from the gateway (autonomous operation). This is done to conserve battery life. Consequently, after a gateway reboot, the sensor’s status remains unchanged until a new signal is received from the sensor. In contrast, devices connected to a neutral wire (220V)—which act as repeaters—transmit information via the Zigbee channel immediately.
That’s correct, it’s not possible to notice this immediately. Given basically all devices report their battery state, they won’t sleep forever though. I have also been thinking about setting up some health checks for my set up as otherwise it often takes quite a while to notice issues once you are beyond a certain amount of devices
That is the distinction I would want a health check to show: “no fresh report since the hub restarted” rather than immediately declaring a sleeping sensor offline. A last-received timestamp and a separate “automation observed after restart” result would make the uncertainty visible without assuming every sensor reports on the same schedule. Would you track those two checks separately?
Yes, the last-received timestamp is what I’d use. Not sure I understand the "automation observed after restart”. If an automation tries to control a device or will was l fail and mark the device as offline is it doesn’t respond. Automations relying on the device as sensor either don’t trigger or have to rely on the previously reported value (and can check how old it is if necessary).
By “automation observed,” I meant a fresh physical sensor event after the restart followed by the expected action—not an attempt to poll a sleeping sensor. That would be an optional end-to-end check, separate from the last-received timestamp. Your distinction between a missing new trigger and an automation using an older reported value is exactly why I would keep those two indicators separate.
