All qmy Aqara devices have connection problem with Hub m2. Any have same problems? How you fix it?
@unkids Hey there! Sorry to hear you’re running into connection issues with your Hub M2 after that firmware update — that’s definitely frustrating when everything was working before.
A few things worth trying based on common Hub M2 troubleshooting steps:
First, check the hub itself:
- Is the Hub M2 showing as offline in the Aqara Home app, or is it online but your accessories are dropping?
- If the hub appears offline, try unplugging it for about 10 seconds and plugging it back in — sometimes a simple restart clears post-update glitches.
If the hub is online but devices won’t respond:
- Try the “Effective Range Test” from your accessory manuals — press the setup button and listen for “normal link confirmed” to verify communication with the hub is actually working.
- Move one problematic device closer to the Hub M2 temporarily to rule out range/interference issues.
- Force-close and reopen the Aqara Home app, or restart your phone to clear any cache weirdness.
Worth double-checking:
- Make sure your router’s 2.4GHz band is stable — the M2 doesn’t use 5GHz, and some firmware updates can reset network preferences.
If nothing helps, this might be a firmware-specific bug that needs official support eyes on it. You can reach the Aqara Home App Customer Service Team via Profile > Help & Feedback > Customer Service, or scan the QR code below — they’ll have more visibility into any known issues with v4.0.6_0654.
No Aqara Home account? You can also create a ticket here.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Anyone else hit this after the v4.0.6_0654 update? Would love to hear what worked (or didn’t) for you.
