After weeks of frustration with my AHT10 sensor, I finally found a solution that works! The error Communication with AHT10 failed! was driving me crazy, but by tweaking the initialization command in the ESPHome code, I managed to get it up and running. Here’s how I did it:
Problem Identification: The sensor wouldn’t communicate properly, and the logs kept showing the same error. I tried everything from checking the wiring to using different libraries, but nothing worked.
Research and Solution: I stumbled upon the Adafruit AHTX0 library and noticed that they write the calibration command without checking for errors. Inspired by this, I commented out the error check in the ESPHome code. The sensor now initializes without issues!
Implementation: I copied the AHT10 component files to my local directory, made the necessary changes, and added the external component to my configuration. The sensor started working immediately, and I could finally see accurate temperature and humidity readings.
Testing and Validation: I tested the sensor under different conditions to ensure it was reliable. It worked perfectly, and I even set up a small script to log the data over time.
This fix not only solved my problem but also gave me confidence in my ability to troubleshoot complex issues. If anyone else is struggling with their AHT10 sensor, give this method a try—it might just save you from pulling your hair out!
Pro Tip: Always check the initialization process when dealing with sensors. Sometimes, a small tweak can make a world of difference. Happy hacking! ![]()
