AirGradient Outdoor Monitor: A Comprehensive Review and Experience
I recently decided to invest in an outdoor sensor to monitor air quality, and after some research, I chose the AirGradient Outdoor Monitor. I wanted to share my experience and insights with the community, as I believe it could be helpful for others considering this device.
Assembly and Setup
I ordered the sensor as a kit, which arrived within two weeks from Thailand. Assembly was straightforward thanks to the detailed instructions on the AirGradient website. The only tool required was a small torx screwdriver, which was included in the kit. While assembly was simple, I can see how someone with limited technical experience might prefer the pre-assembled version.
Integration with Homey
Connecting the sensor to my Homey ecosystem was a smooth process. Here’s a quick rundown of the steps:
  1. Power up the sensor using the included USB-C cable and a 5W USB charger.
  2. Connect to the sensor’s Wi-Fi network and input my home network’s credentials.
  3. Start the inclusion process through the AirGradient app.
Within minutes, all sensor values were available in Homey. Some readings took a few minutes to stabilize, but overall, the setup was seamless.
Performance and Features
I’ve been using the AirGradient Outdoor Monitor for over a week now, and I’m impressed with its performance. The sensor measures temperature, humidity, PM, VOC, CO2, and NOx, and the readings are quick to respond to changes in the environment. For example, when a neighbor started burning something nearby, the sensor immediately picked up the increase in PM levels.
One feature I particularly appreciate is the ability to adjust the update interval between 15 seconds and 5 minutes. This customization is great for balancing real-time monitoring with battery life optimization. Additionally, the option to share data with AirGradient’s community map is a nice touch for those interested in broader environmental awareness.
Areas for Improvement
While I’m very satisfied with the device, there’s one feature I’d love to see in future updates: the ability to set a fixed IP address directly on the sensor. This would make network management slightly easier, especially for those with more complex setups.
Conclusion
Overall, the AirGradient Outdoor Monitor has been a fantastic addition to my smart home setup. It’s reliable, integrates smoothly with Homey, and provides valuable insights into outdoor air quality. If you’re looking for an affordable and effective outdoor sensor, I highly recommend giving this one a try!
Looking forward to hearing others’ experiences with the AirGradient Outdoor Monitor or similar devices. Let’s keep the conversation going!
Cheers,
