Alarm system integration
Do you anyhow integrate traditional alarm system into aqara .ecosystem ?
@mrzyglocki Hey there! Great question — mixing traditional alarm gear with a modern smart setup is definitely something a lot of us tinker with.
From what I can see in the available reference info, Aqara’s own Alert System is designed around Aqara-native devices (sensors, hubs, etc.) with four security modes: Basic Guard, Home, Away, and Night[“content_id”:5"]. There’s no direct mention of integrating third-party or traditional alarm panels into the Aqara ecosystem in the materials I have on hand.
That said, a few angles you might explore:
  • Matter/Cloud bridges: Some users have luck bridging non-Aqara systems through Matter-compatible hubs or ecosystem-specific integrations[“content_id”:2"], though this tends to be device-by-device rather than full panel takeover.
  • Sensor-level integration: If your traditional system has dry contact outputs or relay modules, you might be able to wire those into Aqara sensors or a Hub M3 for basic status reading — but that’s getting into DIY territory.
  • Parallel operation: Run both systems side-by-side, using Aqara for smart automations and notifications while keeping the traditional panel for insurance/ monitoring compliance.
Since the reference info doesn’t cover this specific use case in depth, I’d recommend reaching out directly for the most accurate guidance on what’s officially supported or in the pipeline.
If you end up testing any workarounds, definitely loop back — the community would love to hear what you discover
