I try to use the Aqara window sensor to send me an alert at 11pm if the window is open. I only receive notification once it is opened or closed, but I fail to use the state opened to set up an alert of the window is still open once I go to bed. Did anyone realize that using only Apple HomeKit?
Which app are you using. Could you please captures a screenshot on your current setting? If I understand correctly, do you want to trigger the event notification of opening and closing when you sleep? If so, you can set the execution time of the automation action.
Not sure if you could create alerts like that with an automation in Apple Home. However you could try set this up via the Apple Shortcuts app instead
