Hey everyone, I wanted to share my experience with configuring Alexa in Home Assistant. I recently ran into an issue where I couldn’t exclude certain entities from being listed in Alexa, which was a bit frustrating. After some research and trial and error, I figured it out!
The Problem: I added a list of entities to exclude in my configuration.yaml file under the Alexa cloud configuration. However, I kept getting errors that prevented the setup from completing successfully. The error message mentioned issues with the exclude_entities list, but it wasn’t very clear on what was wrong.
The Solution: After some digging, I realized that the syntax I was using might have been incorrect. I made sure to properly format each entity and double-check the indentation. Here’s what my corrected configuration looks like:
yaml
cloud:
alexa:
filter:
exclude_entities:
- automation.change_brightness
- automation.coming_home_and_dark
- group.all_automations
- light.hallway_2
I also noticed that some of my group names were duplicated, which might have been causing the issue. Removing the duplicates helped a lot!
Tips for Others:
- Check Indentation: YAML files are very sensitive to indentation. Make sure each level is properly spaced.
- Verify Entity IDs: Ensure that the entity IDs you’re trying to exclude actually exist in your system.
- Test Incrementally: If you’re adding a lot of entities, try testing with a smaller list first to see if it works before adding more.
I hope this helps someone who’s struggling with similar configuration issues. It was a bit of a learning curve, but I feel more confident now in tweaking my Alexa settings!
Happy automating! ![]()
