Hey everyone, I’ve been diving into the world of smart home automation lately, and I wanted to share some of my experiences and questions with you all.
First off, I’ve been exploring the Alexa integration with Home Assistant. I came across the Alexa Integration Manual and was a bit confused about the difference between the Automated setup and Manual setup options. From what I understand, the Automated setup requires Home Assistant Cloud, but I’m not entirely sure if that’s the case for the Manual setup. Is it safe to assume that Manual setup doesn’t require a Home Assistant Cloud subscription? I’d love to hear your thoughts on this!
On another note, I’ve been experimenting with setting up a smart garage door system using a Schlage lock and a mimolite garage door controller. After updating to Platform 2.1.1.114, the Schlage locks worked perfectly, but the mimolite controllers stopped responding. I had to roll back to version 2.1.0.123 to get everything working again. Has anyone else encountered similar issues with specific devices after an update? I’d appreciate any insights or solutions!
Lastly, I’ve been on the hunt for a reliable motion sensor that can integrate seamlessly with my Homematic system. Ideally, it should be battery-powered, trigger an action on Homematic, and have a digital output to control an IP camera. I’ve been searching forums and product listings, but I’m not sure if such a sensor exists. If anyone has recommendations or has successfully set up something similar, I’d be thrilled to hear about it!
Overall, this journey into smart home automation has been both exciting and a bit challenging. I’m looking forward to learning more from the community and sharing my experiences as I continue to explore this fascinating world. Thanks for reading, and feel free to drop your thoughts below!
