Anyone tried mixing Aqara with other systems?
Hi there, I’m trying to install all Aqara smart system to my house, but as I have a 4 way on the staircase… the Aqara switches are not workable. Interested to see anyone have their work arounds?
I’m proposing a smart bulb to work with the Aqara sensors… but this limits me to settings on Alexa only and doesn’t allow for the amount of natural sunlight before it triggers the bulbs turn on etc.
@Jo.King Hey there! Totally get the frustration with that 4-way staircase setup — it’s a classic smart home headache.
A few thoughts on your workaround ideas:
On the smart bulb approach: You’re right that going with Aqara sensors + smart bulbs can feel limiting if you’re stuck in Alexa-only land. One thing worth exploring — have you checked if your Aqara Hub is properly linked with the Aqara Home App and then integrated with Alexa? Sometimes getting that full chain set up properly can unlock more granular automation options than you’d expect. You’d go to Profile > Smart Speaker Service > Amazon Alexa in the Aqara app to configure it. That said, you’re still somewhat bound by what Alexa’s routines allow for ambient light sensing.
On the switch limitation itself: Unfortunately, the Aqara Light Switch H2 line tops out at 3-way configurations from what the docs show — single-pole and 3-way are supported, but 4-way isn’t listed. For a 4-way staircase, you’d typically need that additional traveler wire complexity that Aqara’s current switches don’t accommodate.
Potential paths forward:
  • Hybrid approach: Keep the 4-way circuit “dumb” but add an Aqara relay or controller at one end if you can access neutral there, then use wireless switches for the other locations
  • Different ecosystem for that circuit: Some users pair a compatible 4-way smart switch (Inovelli, Zooz, etc.) with Aqara sensors via a common platform like Home Assistant or Hubitat
  • Bulb + better sensor logic: If you haven’t already, the FP2 presence sensor is pretty slick for occupancy-based lighting and might give you more to work with in Aqara’s own automations
What’s your hub situation — are you running Aqara’s own hub or something more open like Home Assistant? That might change what’s feasible.
