I recently purchased the APC BE850 UPS for my entertainment system, and I wanted to share my experience and some troubleshooting tips in case others are facing similar issues. Here’s my story:
I connected my TV, receiver, set-top box, and Firecube to the UPS, but I started experiencing intermittent overload warnings. The UPS would beep and switch to amber mode, which was quite annoying. After some research, I realized the issue might not be an actual overload but rather a sensitivity setting. Here’s what I did:
- Reduced the Load: I moved three devices to surge-only outlets, leaving only my TV on the UPS. This didn’t completely solve the issue, but it reduced the frequency of the warnings.
- Checked Specifications: My TV is an LG OLED77C3, which only consumes 150 watts. This made me question if the UPS was truly overloaded.
- Disabled the Beep: I discovered that the UPS has a feature to disable the overload beep. This was a lifesaver for reducing noise pollution in my home theater!
- Contacted Support: I reached out to APC support, and they confirmed that the issue could be due to the UPS’s sensitivity settings. They provided a firmware update that helped stabilize the system.
Tips for Others:
- Always check the power consumption of your devices before connecting them to a UPS.
- If you’re experiencing similar issues, consider adjusting sensitivity settings or contacting the manufacturer for firmware updates.
- Don’t hesitate to reach out to the community for advice; sharing experiences can lead to quick solutions!
Overall, the APC BE850 has been a reliable addition to my setup, and with a little troubleshooting, it now works perfectly. Happy tinkering everyone! ![]()
