APC InRow Compressor Cycling and Configuration Tips
I recently installed three APC ACRD101 modules in our datacenter and wanted to share my experiences and tips for anyone else dealing with similar setups. Initially, I was a bit puzzled about the configuration options, especially since our datacenter uses a hot aisle setup. I configured the units as standalone but wasn’t sure if the HACS mode was necessary. After some research and consultation with the community, I learned that while HACS mode is ideal for hot aisles, the InRow mode can still work effectively if properly managed.
One challenge I faced was the compressor cycling too frequently. This was particularly noticeable when the outside temperature fluctuated. At around 20°C, the humidity levels indoors would spike, sometimes reaching 80%, which was uncomfortable. Conversely, when temperatures rose above 30°C, the system would trigger high-temperature alarms. I discovered that adjusting the supply air temperature settings and ensuring proper ventilation helped mitigate these issues. I now set the supply air temperature to 19°C and monitor the system closely to prevent unnecessary cycling.
Another observation was that the web interface sometimes didn’t maintain the set supply air temperature accurately. It would show readings around 16.5°C even though I had set it higher. I found that periodically recalibrating the sensors and checking the firmware updates resolved this inconsistency.
For anyone else setting up APC modules, I recommend:
  • Regularly monitoring temperature and humidity levels
  • Updating firmware to the latest version
  • Testing different configuration modes to find the best fit for your environment
  • Keeping the compressor cycling in check by adjusting supply air settings
Overall, the APC modules have been reliable, and with a bit of tweaking, they provide efficient cooling solutions. If you’re facing similar issues, don’t hesitate to reach out for advice or share your own tips!
