Is there any way to integrate zones and everything from the Aqara sensors like FP400, etc?
For the FP400, yes for zone occupancy, but not for everything shown in Aqara Home. Aqara’s official feature table says to configure the zones in Aqara Home first, then share the sensor using the Matter pairing code generated there. The zones can then be used as separate occupancy sensors in Home Assistant. Adding it directly to a third-party Matter platform without that Aqara Home setup does not provide custom zones.
The live positioning map and real-time headcount are not shared through Matter, so I would not expect the entire Aqara view inside HAOS. Are you using the FP400 over Thread, or connected by Zigbee to an Aqara hub? That will help narrow down the right sharing path for your setup.
Thanks @technotron007 for the detailed explanation! Very useful ![]()
Zigbee
For an FP400 paired by Zigbee to a compatible Aqara hub, you share the hub’s Matter bridge with Home Assistant. That is different from commissioning the FP400 itself over Thread. Aqara’s FP400 documentation says the Zigbee sharing code comes from the corresponding hub’s “Third-Party Matter Ecosystems” page.
Which hub are you using, and is it already added to HA through Matter? If the FP400 is instead paired straight to HA’s Zigbee coordinator, please say which integration you use, because the Aqara hub-sharing instructions would not apply. I would establish that before resetting the sensor or changing protocols.
I am noticing something, when I started creating zones in the Aqara App also appear in my HomeKit (HAOS), nice, lol
