I have some nice big Venetian blinds I’m looking to retro fit automating. Does Aqara have a solution that would work for cords to pull one cord to open and another to close? Everything I see requires beads or the more expensive solutions like Iblinds go inside the top which looks quite fiddly. Was hoping for a box I could stick on the wall that you feed one end of the open cable in one hole and the other end to another hole and just calibrate open vs. Closed rotations, if that makes sense? I have 5 windows I manually open twice a day and would love to have a sunrise sunset automation for them ![]()
I would like to know this too. Must be a lot of demand for a product to be developed like this.
I guess the Aqara Roller Shade Controller E1 is out of the question? It requires a single looped cable that is pulled in two directions… could you utilise two of these? Have you looked into retrofitting or altering the mechanism itself?
I have these opening my venetian blinds to open / close position, but they dont actually lift the entire blind up or down (don’t need them two) then i have sun blocking roller curtains in my bedroom and they lift these up/down completely…
Thanks, I had seen that but discounted it as all the literature and aqara’s own website says it needs “a beaded single cord” whereas I have two single threads with a little wooden thing on the end of each. £60 a pop to try it to find out seems expensive hence I thought I’d ask in case there’s a better/more affordable solution
Well, I’m familiar with the SwitchBot Blind Tilt, but I’m afraid it might be tricky with a smooth cord.
For the Aqara Roller Shade Controller E1, you’ll just have to replace the cord with a “beaded single cord” if that’s possible. Or simply attach a “beaded single cord” to one of the existing cords. Or get as creative as they do in this video (starting at about 15 minutes) ![]()
