Aqara Bulbs issue
SO I have set everything up in HA, custom dashboard everything works fine.
The issue I am having and after reading Aqara documentation is their bulbs dont go back to 9000k White from an automation routine say from 7am to 10pm
The night settings are they are 50% Blue from 10.01 pm to 6.59am
" Aqara’s spec: these bulbs only make white with their white LEDs up to 6500K. Anything above that, like 9000K, is mixed from the coloured LEDs, so a bulb left in blue stays in colour mode instead of switching back to its white LEDs."
Any ideas of suggestions? @AqaraOfficial
Add a condition in your automation that returns the light to the brightness and color you want after it ends or to turn the light off after the automation ends.
Basically tell it what to do when done.
Should look like this but with your entities (devices)
action: light.turn_on
target:
entity_id: light.aqara_led_bulb_t2
data:
rgb_color:
- 255
- 0
- 0
brightness_pct: 30
sequence:
- action: light.turn_off
target:
I know the above as I built a custom Dash etc for HA, I am in touch with Support and provided all the logs for HA and their Matter Bridge and bulbs.
They are looking into it as it might be a firmware upgrade to fix the issue
