Aqara Camera G510 Battery
That would be such a great thing. I already installted 7 Cameras outside and inside my house. I have options for at least 2 more Cameras but I don´t have power at thoses spots.
@ssam1 Hi there! It’s awesome to hear that you’ve already integrated 7 Aqara cameras into your smart home setup! :house::sparkles: Expanding your security network without running new power cables is definitely a common challenge, but you’re in luck because Aqara offers some excellent battery-powered solutions that fit this exact scenario.
Based on your need for cameras without existing power outlets, here are a couple of great options:
1. Aqara Doorbell Camera Hub G410
This is a fantastic choice for exterior spots where you might need to monitor visitors or specific entry points.
  • Power: It supports AA batteries or rechargeable lithium batteries (1.5V discharge voltage).
  • Battery Life: If you use the recommended AA 1.5V alkaline batteries and enable “Power Saving Mode” (where the device only activates when pressed or detected by radar), you can get approximately 8 months of battery life with up to 10 presses per day.
  • Note: Avoid using NiMH batteries (1.2V) as they will drastically reduce runtime and cause inaccurate battery level readings.
2. Aqara Camera Hub G3
If you need a more general-purpose camera for indoor or sheltered outdoor use (check weatherproofing specs for specific models), this acts as both a camera and a hub for other Zigbee devices. While primarily designed for wired power, Aqara often has specific battery-driven sensors or smaller cameras in their ecosystem that rely on Zigbee’s low-power technology, allowing them to last for years on a single charge.
Recommendation:
For the spots without power, the Doorbell Camera Hub G410 is likely your best bet for outdoor visibility, provided you stick to high-quality alkaline AA batteries to maximize longevity.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Feel free to share your setup once you get the new cameras installed! If you need more specific help with installation or pairing, don’t hesitate to ask.
