Aqara dievices you have
How many smart devices from Aqara do you have at home that make everyday life easier? I have 79 Aqara devices
I don’t think your image worked :slight_smile:
it work now :grinning:
I have 100 that have been added to Aqara home and another 40-50 are waiting to be installed after the renovation.
wow, thats great, I have only 4, but will also change other devices as well :slight_smile:
Nothing even close to you but ive got
Hub m2
Roller blind motors
Door and windows sensors
The latest g410 doorbell
And a ptz that i just use when im away from the house for more than a day or 2
I have 13 different products from Aqara
I’m only just starting out so I have the G4 Doorbell (replacing an infuriating Netatmo nightmare) and a G5 Pro camera replacing an equally infuriating Ring camera… So far they are working great. So stable. Image quality on the G5 is amazing.
With Aqara magic happend :grinning:
I have W100, U200, P2, T2 rgb . I wonder how much functionality i miss by not using an aqara m3 hub.
Still building my system.
I have:
Roller blind motor
Radiator valve E1
4 x temperature sensors
2x TM1 ceiling lights
Hub M2
Door bell G4
I have 15. but planning to add a couple of G5 cameras.
Already have u200 in front and back door but would love to have an aqara outdoor lock for my garden door.
13 devices, most of them smart energy sockets, but also a radiator thermostat, curtain driver and a led strip…all integrated with Home Assistant. Happy customer!
it depends on which communication features are important to you, otherwise it works with what you have
40 Aqara and 35 other
They slowly creep up in count as you continue to add this and that.
I have the the following:
E1 hub (not used any more)
M3 Hub
4 x radiator valves (1 physically broken :frowning: )
4 x temp sensors
3 water leak sensors
T1 cube
T1 light strip
FP2 presence sensor
Several push button switches
Currently around 20, and more coming after releases of new nice stuff!
Only one camera so far
So far Aqara wise I have:
  • 6x Mini Wireless Buttons
  • 4x Temperature and humidity sensors
  • 1x FP2 Sensor
  • 1x H1 Light Switch
  • 1x E1 Hub
    And I’m planning to get 7x radiator valves.
However, my other smarthome devices include:
  • 8x Eufy Cams
  • 2x Eufy Homebase
  • 1x Eufy E340 Doorbell
  • Eufy E15 Robo Mower
  • Eufy E28 Robo Vac/Mop
  • 8x Nest Smart Smoke alarms
  • 15x Shelly smart plugs
  • 6x Tapo smart plugs
  • Hive heating/thermostat
  • Raspberry Pi 4 (Home Assistant) with SonOff Zigbee antenna
  • 4x Innr Zigbee smart plugs (as range extenders)
  • Hue bulb
  • 3x LinkNLink presense sensors
I need MOOOOAR Smarthome!
I need something with an handle. like the U300 but In Europe the choices of smart lock are quite limited.
