I’ve had both a U200 and U300 for over a year now, connected to Apple HomeKit directly as I don’t own any Aqara hubs. From time to time, both door locks randomly become unresponsive in the Home app on my iPhone, but continue working fine on other Apple devices, including my MacBook and my wife’s iPhone. All other HomeKit devices (though none are Matter/Thread) work normally on all devices. If I don’t bother fixing it, the issue usually resolves itself after a few weeks. However, this obviously sucks if I’m away on a trip.
Setup:
∙ Locks connected via Matter over Thread (no Aqara hub)
∙ Home hub: Apple TV 4K (Wi-Fi only, no Thread)
∙ Also have HomePod minis (Thread-capable)
∙ All devices on same iCloud account
What I’ve tried:
∙ Restarting devices, force quitting Home app
∙ Signing out/in of iCloud on my iPhone (this fixes it, but issue eventually returns)
∙ Removing and re-adding locks (works for months, then issue returns)
The issue is device-specific and intermittent- it works fine for months, then suddenly only my iPhone can’t control them while other devices still can.
I’m guessing this is an Apple/homekit issue, but just wondering if anyone else has experienced this before and has any suggestions?
I’ve experienced this kind of issue before since I have many (30+) devices on HomeKit. My eero network couldn’t handle all the devices and so intermittently some devices went offline. I switched to a ubiquity system and added more nodes to my mesh; I rarely encounter this issue now. How many smart devices do you have?
Matter devices can be a bit different in their behavior. Changes in ip as mentioned and not enough border routers to spread the load can be problematic. If you’re looking to just keep everything directly in Apple home you may want to purchase a device that is plugged in and has thread border router functionality. The Aqara m100 hub can do this as well as the G410 doorbell. The M3 hub is another one that is amazing.
I’d also take a look and make sure IPv6 is enabled and working on your wireless router/modem.
If you’re not interested in adding door/water leak or any of the sensors then the G410 doorbell can go direct into Apple
Home and act as a thread border router. The bonus is that it’s also a hub in case you ever want to grab sensors as well. (They are excellent btw)
Thank you for the suggestions. I’m waiting to get the W200 and also looking at the G400 or G410, so hopefully having one of these hubs will prevent this issue in the future.
