Aqara E1 Blind Controller Setup Issue
Hi everyone! I’m really excited about my new Aqara E1 blind controllers—they seem like a fantastic addition to my smart home setup. I’ve successfully paired them with my ZigBee2MQTT system, and everything works smoothly in the ZigBee2MQTT UI. However, I’ve encountered a bit of a hiccup when integrating them into Home Assistant. The blind shows only a single cover option in the UI, and it doesn’t update its state unless I manually refresh the ZigBee2MQTT device. This is a bit frustrating, as it stops me from using the blind seamlessly through Home Assistant. I’ve tried searching for solutions online, but I haven’t found anything that quite fits my situation yet. Has anyone else experienced this issue, or perhaps has a workaround or tip to share? I’d be incredibly grateful for any advice or insights you might have. Thanks in advance for your help!
