Hi wveryone!
Is it possible to pair two thermostatic radiator heads, so that when one is manually adjusted to set a temperature, the other automatically takes over the same value?
Hey there and welcome to the forum.here are some tips to do that depending on which platform you want them to be made.
Synchronize their temperatures through your smart home hub or app (such as Apple Home, Home Assistant or Aqara using one of two methods:
Room Grouping / Climate Groups: Most smart ecosystems allow you to assign multiple radiator valves to a single “Room.” When grouped, adjusting the target temperature on one valve or via the app automatically updates all other valves in that same group.
Automations / Routines: If your platform doesn’t support native room grouping, you can set up a simple automation: When Thermostat A’s target temperature changes, set Thermostat B’s target temperature to match.
If you choose Home Assistant, I’d check the reporting first: adjust one E1 physically and see whether its target temperature changes in HA. The value to mirror is the setpoint, not the measured room temperature. HA documents watching an entity attribute and setting a climate target, but this depends on your integration reporting the manual change and accepting a target on the other valve.
For two-way synchronisation, I’d only send a command when the destination’s target differs, then test each valve separately before involving schedules. That helps avoid the two rules echoing changes back and forth. I use Home Assistant for climate automations, but this is a control-logic suggestion, not a tested E1 pairing recipe. Which hub and app are you using?
