Aqara FP2 gets worse over time
Hi everyone. I’ve had the FP2 sensor for quite some time, but I’ve noticed that the readings have gotten worse compared to when I first started using it. Has this happened to anyone else?
Hey there.yes I agree with you mine was working perfectly before the last 2 update and i see that now works well then then the minutes pass it start behaving weird it detects me and when I go out it still think I am in that zone also sometimes I got that my light turned off with me in the kitchen.i already speaking with Aqara support but I need to check it a bit more and see if this behavior persist
I also recommend you to contact aqara support too and point your issue as they will ask to give them permission to monitor it this way they would know what it need to be fix
Well I do not know how but yesterday I was playing again with my zone I remake it 2/3 times and also I placed my sensor again on the same spot were I add it originally and since yesterday it works perfectly fine so will have to see if will keep this working path or not.
As soon as I have a moment, I’ll give it a try.
I run five FP2s and haven’t had it get worse over time. What exactly is it doing — false presence, missing you, or holding on after you leave? Also which firmware and are you on HomeKit or just the Aqara app? coccolino_26 got theirs back to normal by redrawing the zones, so that’s worth a try.
Yes I did that and still today 2 times didn’t turn the light off I had to enter on the kitchen again and get out to turn the light off all this happened after I was more then 1/2min in the kitchen is weird but this was happening before too.if I still see this behavior I will report it as I already in touch with Aqara support ether way is much better then before I hope it lasts.
My be you need to make the space between those zones adding an row to existing one meaning the white part so it with 2 rows see if helps improve the accuracy of the detection
Sometimes it’s the room that changes more than the sensor: moved furniture, a plant, a fan, new curtains. There’s an option in the app to automatically add interference sources. Running it with nobody in the room, and redrawing the zones if things moved, often helps.
If it’s still not great after that, it’s worth noting whether it started after a firmware update. Support will probably ask.
Well my fix was to set it back to the original place we’re had issues with detecting and I remade my zone again sure all after an reset and that for me fix it now it works 97% of the time
