Aqara fp300 Bad performance
My FP300 in the kitchen is performing very poorly. It consistently detects people quite late and sluggishly; I’ll have been in the room for a few seconds before it finally triggers—by which point I’m almost on my way out again. Can anyone help me with this? Also, how can I switch a sensor that was moved to Zigbee back to Matter without using an Aqara hub?
If you reset it and then go to re-pair it through the app it should let you choose matter or ZigBee. Are you using home assistant. Is it set to use PIR or presence or both for detection.
