Aqara fp300 bathroom
Has anyone used an fp300 in a bathroom coupled with a humidity sensor using a decent blueprint in home assistant? Suggested blueprint appreciated.
I use three FP300’s in three different bathrooms and they work great however I don’t use blueprints. I’ve never found a need to create one or download someone else’s.
They do work well in the bathroom environment
You don’t need a blueprint for this — the FP300 already has a humidity sensor built in, so you’re not even wiring up a second device.
In the Aqara app there’s a native ‘Humidity rises to / drops to X%’ trigger, ready to go. If you want it in HA instead, the humidity reading comes through as its own entity just like temp does on mine, just build a normal automation off that, no blueprint needed.
Only gotcha: keep it away from the bathroom fan/vent or you’ll get noise in the readings."
