Anyone else facing the issue with FP400 dropping from Apple home? I have it setup via Zigbee (M100 hub) and transfer the zones to apple home. It works for a day or two and then drops completely from Apple home. Still there in Aqara app, but unresponsive and stuck at the same number of person count as it detected when last available in Apple home.
Hello, I have a few suggestions:
- Check the adapter used to ensure it is of the quality 5V-1A as required.
- Check the network stability.
- Check the Thread network.
Hope to receive your subsequent feedback~
As @ming_wen mention check all that more see also that your M100 doesn’t loose internet connection as if you have it set as zigbee the M100 is what control network also on apple home app if you have multiple apple devices set one as main controller on the hubs section.
I have one of my homepods set as the hub. Power isn’t an issue because FP2 never disconnected and I simply switched FP2 with the 400 as I had it mounted on the bracket on a corner.
The M100 has 6 other child devices and none of them have any issues (for over 5-6 months now).
Would try switching the brick though and see.
Is the power consumption between FP2 & FP400 different? Couldn’t find anything on the boxes. Asking because i replaced the fp2 with the 400 (using the same cable) and fp2 never had any issues. I replaced because of the range and multiple people detection with fp400.
My wifi network is strong as I have a router pretty close (less than 3 feet) from the M100 hub and the less than 5 feet from fp400.
Have set it up with Zigbee because of the multi zone setup benefit.
Well if on Aqara home app works and you do not have disconnection issues then it is on apple home app so there you need to see what is causing that.by the way the FP2 uses usb adapter but FP400 uses type C so you could also try an apple adapter for it since is more advanced then the FP2.my FP2 works perfectly with an Samsung 5v power adapter but my FP400 is powered by the 20w apple adapter and works perfectly
Have changed the adapter. Shall update if this solves the issue ![]()
Changing the adapter did not help ![]()
I also tried using Thread (with M100 as Aqara app does not give me homepod as options when selecting the thread matter controller) but FP400 shows as No Response in Apple Home after a few mins of setting it up.
Then the issue is on your thread network as if only on apple home app shows offline that means that your thread network have issues or that the HomePod is far from the FP400 and that makes it to disconnect.
FP400 has been stable connected to Home assistant and then shared to Homekit for me.
FP400 is in the same room as the homepod though. I have multiple homepods in the rooms and the apple tv is wired to the main router (in the mesh network). no other device is facing this issue. FP2 worked better(just that it didnot detect person at the end of it’s range where my dining table ends). FP400 solves that issue, but it keeps on dropping.
The funny and frustrating part is that when I set it up using Zigbee, whichever M100 hub I pair it to disconnects & goes offline from Aqara app and apple home after a few hours. Need to keep on restarting (disconnecting and reconnecting the hub) to make it work again but that causes only the FP400 to disappear from Apple home! Not sure what’s going on.
Are you using Zigbee or Thread option? Did you set it up in Aqare home app and then send it to HA?
I’m using Thread because the zigbee firmware I don’t think it’s fully ready. I set up in app then to home assistant.
if you have the M100, can you try Zigbee instead of thread? If you don’t have a strong thread network built out you may have problems and the addition of the M100 as the matter controller benefits Aqara app, but not Apple Home. The Homepod is carrying the weight for Apple Home thread network, and while the M100 should have join to the existing thread network, it may not have.
I did set it up using Zigbee initially. But it causes the M100 hub to do offline for some reason taking all other 4-5 devices along with it. I tried it with both of my M100 hubs. Does the same to both.
So thought would try Thread and it now disconnects from Apple Home alone (using the M100 as the Thread hub).
Would try the zigbee option again as that at least worked, and move the M100 as close to the FP400 as possible.
I have been thinking of moving to HA, and this might be the push I need to invest in that ![]()
You shouldn’t have this much trouble honestly. If you’re getting major disconnect issues on both protocols, something bigger may be wrong. Might be worth working with support to analyze.
Well something weird is happening there if on both protocols it goes offline.you need to contact Aqara support.as at this point you can’t do much.mine is on the bathroom and my Apple TV and HomePods are on living room and there are 2 walls in between and it works perfectly
It definitely is. Zigbee isn’t working either. Did the same thing again. Messed up all of my devices linked go that M100 hub & removed itself from Apple Home as well. Reporting this to the support team now.
