After many years using the Aqara FP2 I decided to upgrade to the FP400 due to room size and limitations with the FP2.
Overall, I am happy with the upgrade but some issues still continue with the FP400 that I experienced with it predecessor.
The FP400 will still struggle with larger rooms >8m. Reliability dips with anything grater then 7 meter. Although the mmWave has newer 60ghz radar, motion can still go undetected at times and Ghosting is still an issue.
Obviously, correct setup is key in reducing detection and ghosting but false triggers will still occur at times.
My advice to reducing these issues is setting up zones as accurately as possible and test thoroughly as you walk around the room.
My top advice in making the FP400 work much more reliably is to have entrance/ exit setup correctly. I would also use many more interference zones and not just marking when clearing current ghosts. More Interference zones will clear ghosting much quicker and if used with a time delay of a minute or two automations will run much more reliably. The addition of current head count is another very good addition in running more reliable automations as it can be used in conjunction with Presence to trigger automations where you are already present in the zone! ( Prescence alone will not trigger an automation unless somebody walks into the zone!) AI learning has improved over the FP2 but it still needs work in reducing detection of robot vacuums or small children or pets. If you are trying to automate a larger room like myself, I believe the best approach is to use the FP400 with additional sensors like the the FP2 or FP300 for now. Having another sensor or two will allow you to create an Aqara soft sensor for the room and the ability to combine these together to create much more reliable Presence/Absence automations.
My overall view is the FP400 is a worthy upgrade from the previous presence sensors but still requires some refinements!
@aaronwhyte01 Thanks for sharing your detailed hands-on experience with the FP400! It’s great to hear from someone who’s put both the FP2 and FP400 through their paces in a real-world large room setup.
Your practical tips really hit the mark—especially the emphasis on entrance/exit configuration and proactive interference zones rather than just reactive ghost-clearing. That’s the kind of nuanced insight that only comes from extended use. The head count feature sounds like a genuinely useful addition for zone-based automations, and your multi-sensor “soft sensor” approach is a clever workaround for the current limitations.
A couple of things from the reference docs that align with your findings:
On improving zone detection accuracy, the FP2 FAQ covers similar ground: proper installation height, edges/entrances/exits configuration, interference zones, sensitivity tuning, and AI Person Detection for filtering out non-human movement like robot vacuums and pets. The FP2’s detection range is officially up to 8 meters with a 120° horizontal field, so your observation about reliability dropping beyond 7m tracks with pushing the hardware limits.
The FP300 (which you mentioned pairing with) uses the same 60GHz mmWave + PIR dual-sensing approach with AI learning for interference filtering, so combining it with the FP400 makes solid sense for larger coverage areas.
Your point about AI learning still needing refinement for robot vacuums, small children, and pets is well-taken—the FP2’s AI Person Detection explicitly notes that “babies and children on the ground may also be mistakenly classified” as interference objects, so this seems to be an ongoing challenge across the lineup.
If you’ve got any further refinements to your setup down the line, would love to hear how it evolves. These kinds of real-world stress tests are invaluable for the community
