Is anyone currently using Frigate and the G100 in HASS? The setup was easy (RTSP), sometimes I do get a bit of distorted image (half of screen random pixels) unlike in my G5 Pro?
@adriaanmgouws It sounds like you’ve successfully set up your Aqara G100 with Frigate using RTSP, which is great to hear! The distortion issue you’re experiencing, where half of the screen shows random pixels, might be due to network stability or bandwidth limitations. The G100 supports high-resolution streaming, and any network hiccup can lead to such visual artifacts.
Here are a few suggestions you might find helpful:
Network Check: Ensure that your Wi-Fi network is stable and has sufficient bandwidth to handle high-resolution streams. You might want to check the signal strength where the camera is located.
Camera Settings: Double-check the camera settings in both the Aqara app and Frigate to ensure they are optimized for your network conditions.
Firmware Updates: Make sure that your G100 camera has the latest firmware installed. Updates often include fixes that can resolve such issues.
Comparison with G5 Pro: Since you mentioned that the G5 Pro does not exhibit this issue, consider comparing the settings and network conditions of both cameras to see if there are any discrepancies.
Feel free to share any additional insights or solutions you discover. It would be great to hear from others who might have faced similar issues and how they tackled them!
@adriaanmgouws It’s great to hear the RTSP setup for your G100 with Frigate in HASS was easy! For the G100, RTSP functionality is supported, and the general setup steps involve using a media player like “URL Media Player” to enter the stream link, username, and password (ensuring devices are on the same LAN) .
Regarding the distorted image issue (half the screen with random pixels), the current reference information doesn’t specifically cover this scenario for the G100. It might be helpful to check if other community members have encountered similar problems—feel free to share more details about your setup (like network environment or firmware version) to see if others can chime in!
If you’d like further assistance, you can also reach out to the Customer Service Team via the Aqara Home App (Profile>Help&Feedback>Customer Service) or by scanning the QR code:
Hope you get this sorted soon—thanks for sharing your experience!
