Aqara G3 camera: HomeKit motion notifications while at home after updating to iOS 27
Hello,
Since updating all my Apple devices (iPhone, iPad, HomePod as home hub) to OS 27, I’ve been experiencing abnormal activity notification behaviour from my Aqara G3 camera in Apple Home (HomeKit).
I keep receiving motion notifications every time I walk into the camera’s field of view, even though in the camera’s “Status and Notifications” settings I have set notifications to be delivered only when nobody is home. Before the update, this setting worked correctly.
Has anyone else experienced the same issue? Is this a known problem, and is a firmware update planned for OS 27 compatibility?
Thanks in advance,
I believe if you set “if nobody’s home” in Apple Home, then it’s up to Apple Home to decide if you’re home (unfortunately).
Apple will use your location, UWB (to check if you’re near a HomePod or a MacBook) and connected WiFi network to determine if you’re home and then it will decide if a notification should be sent or ignored.
If it was a notification from Aqara Home, then it’s a different matter
Have you tried updating to 27.0.1?
Thanks for your reply. Yes, that was my first thought too: the issue may lie in how HomeKit determines whether I’m at home. I’ve installed 27.0.1, but it didn’t help. I also contacted Apple Support, and they suggested a full reset of my Home; however, I have dozens of devices connected to Apple Home, so setting everything up again would be a huge job. Before going down that route, does anyone know of a less drastic fix?
Maybe you could start by removing the camera from Home and then adding it again? Maybe Apple Home will see it as a new device and it will fix some stuff like notifications?
If you have multiple Apple hubs (Apple Home → three dots → Home Hubs & Bridges) then sometimes there’s an issue that prevents the Apple Home from syncing some settings properly.
An unstable WiFi or network issue can cause the Apple Home to “save” settings (like device to room assignment or automations), but it’s not actually applied. After restarting the hub, the changes are lost (or still shown in the “new way”, but they are working “the old way”).
I had issues like this regularly with Apple Home, where devices were put back to the default room after restarting my HomePods. Or recently (after updating to iOS 27), one automation refused to change. It was shown as the new one, it was working when tested in Apple Home, but it worked “the old” way when triggered by the presence sensor. I fixed it by removing it and adding it again (and it was painful, it was a big automation with “ifs” for each weekday)
Thanks again for the suggestions. In my case I only have one hub, a HomePod mini, and all my devices are connected to it. My router is a FRITZ!Box 7690 placed close to the hub, so I don’t think it’s a Wi-Fi issue. I had already tried removing the Aqara camera from Apple Home and adding it again, but the problem persists.
At this point I think I’ll have to wait for a HomePod OS update, since it’s still on 27.0. Fingers crossed! I’ll update this thread if anything changes.
